跳转到主内容
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
How do rest my computer if the keyboard isn't working.
Ok I booted my computer the other day and the keyboard isn't working. The power button and the track pad are, and all of a sudden my battery isn't showing up, says it isn't installed. I was trying to work down a list of solutions and one was to do a system reset. But that requires pressing cmd-r, well my keyboard doesn't work. How can I do a system reset if the keyboard isn't working? Thanks for the help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Any USB keyboard will work on the Mac - it should be identified in startup and the key combo should work, give it a go.
这个答案有帮助吗?
得分 1
添加一条评论
If you have a wireless keyboard handy you could try turning on Bluetooth and use the other keyboard. Hint: Use the keyboard mapper app to type in the code (if needed).
It sounds like you have a loose keyboard ribbon cable or you got your system wet. Have you taken off the bottom cover yet to check things out?
这个答案有帮助吗?
得分 0
1条评论:
Machead has a better answer here! Thats what happens when you get spoiled by Apple with there wireless keyboards ;-}
完成的
添加一条评论
添加你的答案
danurbanpgh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,316
