2.26 or 2.4 GHz / White plastic unibody enclosure
678 个问题 查看全部
Repairing liquid damaged keyboard; cleaning shorts?
I've been working on A1342 laptops for about 2 years. In this time, I've acquired approximately 200 top-case assemblies, since this part is so commonly damaged by liquid spills. I know it's extremely difficult to repair these, as it requires prying the keyboard from the case and then tediously separating the layers of the keyboard, alcohol-cleansing the printed circuits and hoping none are damaged beyond repair.
My question is, is there some "method" to repairing these? I've purchased dozens of these from a source who repairs them professionally, and they look BRAND NEW, with no indication of prying or cleaning at all. They won't let me know how they do it, but I could save literally thousands of dollars if I could figure out how to do this.
I was wondering if there was any insight into how this might be done? I'd like to avoid using a heat gun, as it warps the case FAR too easily. I don't want to completely ruin a case that could be repairable.
Any input would be greatly appreciated. My main issue is removing the internal frame from the casing. I have an adhesive that will adequately re-attach the keyboard to the casing, just no good way to remove one from the other without causing obvious pry-damage.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 1
评论:
I'm also intrigued as to how this would be done, it's a question that I've pondered myself!
Man I wish I knew the answer. Its so frustrating when this happens,
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
Just like a magician if he told you the secrets of his tricks you wouldn't be amazed anymore! Just kidding ;-}
I suspect they aren't fixing the keyboards but replacing them. As you point out the hard part is cleaning them and putting all of the pieces back together. Instead, they just take the old one out and put a new one on. At least that is how I would do it if I could find the magic source for the keyboards in China that I could order them from.
As to the glue I would use a hair drier Vs a heat gun as you don't want to over heat the plastic. Cleaning the glue off with the correct solvent also helps here.
这个答案有帮助吗?
按维修分数 2
添加一条评论
添加你的答案
Steven 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 4
总计 982
