跳转到主内容
加入维修社区 - 创建账户
MacBook Air 11" 的维修指南、手册和故障排除帮助。获取自己维修 MacBook Air 11" 所需的一切。
Right side USB connection won't work?
The right side USB port not working, the left one is OK
How do I repair this?
Gary
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
You don't. USB port repair is not a DIY project. Soldering and repair of components on logic board requires special tools, solder & lots & lots of practice.
A service could repair the board. You could replace the entire logic board (an advanced DIY project). OR, as a work around you could put a USB port adaptor on the working port (however it should be a self-powered port {that's right needs to be plugged into a wall outlet} so you don't blow that one out)
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
1条评论:
While I do agree with Machead here. You could just have blown fuse link for the power services for that port. It might be working, just not offering power. Try connecting a powered hub to this bum port and then hook up your device to the hub does it work then? If so your fuse is blown and that can be fixed with a straight small solder iron and the needed fuse to replace it (if you have good fine dexterity skills & the needed tools). Otherwise its' best to let someone who does this for a living fix it. If that is not the problem its' time for a replacement logic board as the I/O chip is bad.
完成的
添加一条评论
添加你的答案
Gary Cramp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,438
