How to repair Kia Spectra 2004 Speedometer?
How do you test and repair the speedometer that has stopped working but the led odometer still displays. what could be the cause?
Gregory Peris, just like previously mentioned, it sounds more like a Speed sensor or a Cluster issue to me. If your odometer would be out as well, it might be different. To remove the speed sensor disconnect the coupler, remove the holding bolt and twist the sensor out. straight forward job.
这个答案有帮助吗?
usually if the speed sensor is gone the car wont shift it goes into limp mode and you only have 2nd gear and reverse
Do all the other gauges work? If so then the speedometer cable is probably broken.
这个答案有帮助吗?
There is no speedometer cable on this Kia car model, it works electronically via a electrical cable through a speed sensor. Thanks for your kind intentions, Michael ..really appreciate it.
sorry forgot to say , All other gauges are functioning normal, so not able to say if it is a faulty cluster.
I replaced both and my speed meter still dies after 3 miles .My rpm has always kept working don't know what to do next
这个答案有帮助吗?
I'm having the exact same problem, and have also replaced the speed sensor, but no change. Next thing I'm going to replace is the wiring. Any ideas on how to get a hold of the wiring schematics? Mine is a 06' kia spectra
这个答案有帮助吗?
Its a wiring issue if it work when car is cold and dies out after couple min. I replaced ever speed sensor and cluster.
这个答案有帮助吗?
I also having the same problem. I replaced both speed sensors and the dash cluster on 2004 kia spectra. Does anyone know if the cluster is not reprogrammed, will it stop the speedometer from working ?
I put 2 clusters in my 2004 Kia spectra because of the speedometer issue and hadn't programmed neither one of them.My speedo been acting up over a year now and I changed the sensors and tinkled with thr wiring and the speedo works when cold and stop when its hot.Repair cost is very exspensive like close to $1000.It still rides good but drags when the speedo isn't at full operation level
fukk this dumb ass car i hate this muthafucka i been putting too much money into this bittch once you start spending you can't stop because if one dumb ass thing fukk up on this stupid ass kia spectra then something else fukks up right along with it sooooo with that being said FUKK THIS DUMB RETARDED STUPID ASS BITTCH ASS FUKKING CAR BITTCH AND FUKK YOU TOO MUHHFUCKA HOE!!!! BITTCH ASS FUKKING DUMB ASS MUTHAFUCKING CAR UGH!!! I HATE THIS BITTCH.
这个答案有帮助吗?
Ooooooooohhhhh i was maaaaddddddd cracking tha fukk upp lmao laughing my ass off
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 22
总计 27,495
7条评论
Sounds more like a Speed sensor or a Cluster issue to me. If your odometer would be out as well, it might be different. Does your transmission shift normal? Anything else going on with your Kia?
由 oldturkey03 完成的
Sorry for delay Mate, Well transmission shifting is normal, the LED odometer reads but shows the same figures as it requires movement of the speedometer. All else is okay with my Kia Spectra 2004.. and thank God for that. I did have a look at the speed sensor mentioned and it is high on the suspect list. I believe you are right here. Thanks.
由 Gregory Peris 完成的
I have the same problem. Where exactly is the speed sensor located. My Chilton manual does not even mention the speedometer.
由 Mike Curry 完成的
Tameka can you post this as a seperate question please
由 Jimfixer 完成的
My speedometer works perfectly in the morning but wont rise again when after being in traffic for some time. how do i solve this.
由 Ebenezer Sackey 完成的
显示更多的2条评论
