跳转到主内容
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 个问题 查看全部
问题已关闭
Internal memory recover possible?
After i charged the phone it wont start anymore, the screen is bright a couple of seconds.
Im thinking of getting a new one, but i want to recover the internal memory on the old one, is this possible and how?
My computer won´t recognise or find the phone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
添加一条评论
15个答案
最有帮助的答案
its not deleted !@#$.... you guys his phone is broken and he cant do any of the !@#$ your telling him to do
这个答案有帮助吗?
得分 3
添加一条评论
If you can get in download mode but not recovery chances are your eMMC is dead. Very common problem.
You can try flashing full recovery files through Odin and failing that flashing the PIT file through Odin.
If this doesn't work you can reheat eMMC chip in an attempt to reflow it
这个答案有帮助吗?
得分 1
添加一条评论
Coolmuster Lab.Fone for Android could help you recover kinds of files from android phone easily, like sms, contacts, photos, documents, and so on, have a try!
http://goo.gl/CvUnLr
这个答案有帮助吗?
得分 0
添加一条评论
I have the same issue, i contacted a data recovery specialist in here and he said they can get the data from the internal memory after they connect it somehow to tools they have and can directly read the data and store the lost data from it, but it will cost you around 100$/hour, if you like i can give you his number call him and see what you can get
Note: he is in Jordan
这个答案有帮助吗?
得分 0
1条评论:
Can you please share his details? My samsung s3 emmc is crashed, I want to recover data.
完成的
添加一条评论
plzz help me plzzz recove my data ??
这个答案有帮助吗?
得分 0
添加一条评论
Sigh. Doesn't anyone know you can use a custom recovery to attempt to retrieve data out of the phone? You need someone like TWRP (Team Win Recovery Project), Clockworkmod or Philz touch recovery.
I know with this method you can retrieve data from the phone while in recovery menu. If I can remember you need to mount system and data in recovery.
Otherwise just flash correct firmware from Sammobile (make sure correct model number, region (service provider or country)) before downloading the firmware and use the program called ODIN which instructions are given on the sammobile website when downloading firmware.
When you do flash it via ODIN it will not wipe the phone. It will simply either attempt to fix the system firmware or update the phone. Hopefully this is enough to break the boot loop and get it to working.
The extreme method which is expensive data recovery is taking it to someone that is specialized in doing so.
这个答案有帮助吗?
得分 0
添加一条评论
Internal memory doesn't mount as a drive like external memory does. As we have talked about in previous passages, we can use some data recovery program to scan for all lost or deleted data files on Samsung Galaxy S6 SD card, and retrieve them back to your life. However, it seems more difficult when it comes to internal memory. Don't worry. Here is the right choice for you.
Whatsapp recovery software android can solve your problem of Samsung internal memory data loss easily and effectively. It allows you scan and preview your lost data from internal memory, as well as deleted files from SD card. Contacts, messages, pictures, and videos can be got back without any difficulties, just following the simple steps below. Now, read on and follow us, know how to recover lost data form Samsung Galaxy S7/S7 Edge/S6/S6 Edge/S5/S4/Note 4/A9/A7/A5 internal memory with this magic program.
You can also see this tutorial on how to recover whatsapp chat history on samsung.
这个答案有帮助吗?
得分 0
添加一条评论
Hey, I am sorry to hear that. To be honest, I had ever also had the similar data loss problems and had tried many solutions online. Fortunately, Android Data Recovery finally helped me recover data from internal memory with several clicks. Hope you also can learn a lesson to prepare and update data backups in the future. Read more detailed data recovery information to recover data from internal memory.
这个答案有帮助吗?
得分 0
添加一条评论
As more and more people are using Samsung now, undoubtedly, the common problem of data loss annoys Samsung users as well. Such as mistakenly deleting, factory resetting, system crash, SD card broken will lead to your unexpected data loss. Then, people may wonder how to Recover Deleted Data from Samsung. Here I advise you a wonderful recovery program---Samsung Data Recovery.
As a professional data recovery tool, Samsung Data Recovery can Extract and Restore Lost Photos, Videos from Samsung Galaxy, as long as the deleted ones are not overwritten by new data. Then you can preview as well as recover them as you like. It is pretty easy to use and 100% safe.
Read more:
How to Recover Deleted Photos from Samsung
How to Recover Deleted Messages from Samsung
这个答案有帮助吗?
得分 -1
1条评论:
you recovers software spammers need to learn to read " phone it wont start anymore" when it is not working, your software ain't gonna fixit.
完成的
添加一条评论
This is can be restored.You can try to restore the software.
see more:
|[URL=http://www.recovery-iphone-android.com/|recover software]
read more:
[URL=http://recovery-samsung-contacts.blogspo...|Recovery Samsung Contact]
[URL=http://recovery-iphone-data.blogspot.com...|Recovery iPhone Data]
这个答案有帮助吗?
得分 -1
添加一条评论
Here I introduce an Android Data Recovery for you to recover deleted files from Android, here you can turn to Dr .Fone for Android which is powerful enough to recover deleted contacts, text message, photos and videos from Samsung Galaxy S4 and other Android phones and tablets such as Samsung Captivate, Samsung Infuse, Galaxy Nexus, Samsung Epic 4G Touch, Samsung Galaxy Ace, Samsung Galaxy Note and so on.
这个答案有帮助吗?
得分 -1
添加一条评论
Don't worry, Andy. Maybe you can try using data recovery software. If your computer can't detect your phone, try to open the USB debugging on your phone device. Then follow the steps as below:
Step1. Download Android Data Recovery and install it.
Step2. Select the files where you want to recover your data from and click "Scan" button.
Step3. Preview and select the files you want to recover. This provide a lot convenience for users who want to do Android Photo Recovery
Step4. Click "Recover" button to save the recovered files to the destination folder.
Read more about how to recover deleted files on Android. After these steps you could successfully finish the recovery process. As I said it is quite easy, right?
这个答案有帮助吗?
得分 -1
添加一条评论
You can recover deleted files from Samsung galaxywith Samsung Data Recovery. This guide will show you the easiest way to recover messages, contacts, photos and videos from your Samsung galaxy phone
这个答案有帮助吗?
得分 -1
添加一条评论
Download and install Samsung Data Recovery.The software can detect and recover deleted data from android mobile phone and internal memory card.
How to regain lost data /files from samsung cell phone
这个答案有帮助吗?
得分 -1
添加一条评论
You canrecover deleted files from internal memory in Samsung with Android data recovery app.
When you delete files the data itself isn't deleted, just the index entry that tells the system where the data for those files is located. The area containing the deleted data is also now marked as free space so it is available for any new files to be written there instead. If and when that happens, then it is too late to recover your deleted files so it is very, very important to not save any new files or data to the device concerned.
这个答案有帮助吗?
得分 -1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 68,819
