跳转到主内容
The first generation Neon was introduced in January 1994 and manufactured until August 1999. It was available as a four-door notchback sedan and a two-door notchback coupe.
29 个问题 查看全部
Why wont my engine fire or run?
It will turn over. but it will try to start up on starting fluid. tjen it quits trying to run just turns over. whats wrong??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
similar problem on our car turned out to be a loose fuel pump connector..
完成的
添加一条评论
2个答案
I would suspect fuel delivery system and the high voltage circuitry.
这个答案有帮助吗?
得分 0
2条评论:
It has all kinds of fuel pressure. and yhe high voltage circuitry? how might i check that?
完成的
Search this site: bobistheoilguy.com Look in the Automotive and Mechanical forums.
You will also need basic voltmeter and ohmmeter test equipment.
完成的
添加一条评论
i have almost the same problem my dodge neon wont even turn over it doesnt even do a click what do i do ? can anhy body help me
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brandon B 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 290
