跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 个问题 查看全部
My iMac can't boot any system, kernel panic?
Hi, first of all thanks for any help that you can provide me.
My computer can't boot the system, at the first time start to can't find the system and show me a folder with a question mark, so I try to reinstall the system (Lion) and can't boot from the CD or USB, just show up the apple symbol but never more than this. So I proceed to change the HDD for a new one and make a special partition with a bootable "OSX Lion Install" saved inside, and have the same problem.
But then in the apple logo screen start to appear the despicable screen of death (mac version) with the restart message or sometimes just the apple and a kernel panic code in the back, exactly this one:
''''panic(cpu 1 caller 0xffffff80002c2cb5): "Machine Check at 0xffffff80002bcb60, registers:\n" "CR0: 0x000000008001003b, CR2: 0x000000010f66c370, CR3: 0x0000000000100000, CR4: 0x0000000000000660\n" "RAX: 0x000000009cc01065, RBX: 0x7fff
Debugger called: <panic>
Backtrace (CPU 1), Frame : Return Address
0xffffff8040c74ec0 : 0xffffff8000220702
0xffffff8040c74f40 : 0xffffff80002c2cb5
0xffffff8040c750a0 : 0xffffff80002d840f
0xffffff8045913b10 : 0xffffff7f816cef84
0xffffff8045913b50 : 0xffffff7f816c8552
0xffffff8045913c30 : 0xffffff7f816ca371
0xffffff8045913ce0 : 0xffffff80002c41f4
0xffffff8045913d00 : 0xffffff800022d2b5
0xffffff8045913d40 : 0xffffff800022dfa0
0xffffff8045913da0 : 0xffffff800022f353
0xffffff8045913e00 : 0xffffff800021e592
0xffffff8045913e20 : 0xffffff7f80bdd110
0xffffff8045913e60 : 0xffffff7f80bdd30e
0xffffff8045913e80 : 0xffffff7f80bd5d4f
0xffffff8045913eb0 : 0xffffff800062695b
0xffffff8045913f30 : 0xffffff8000626fb9
0xffffff8045913f70 : 0xffffff8000625b9f
0xffffff8045913fb0 : 0xffffff8000820057
Kernel Extensions in backtrace:
com.apple.driver.AppleIntelCPUPowerManagement(166.0)[7FCD8D98-D972-3973-A13B-DC551C536EE6]@0xffffff7f816c6000->0xffffff7f816effff
com.apple.iokit.AppleYukon2(3.2.2b1)[2DF7ECA3-F451-3F61-BF3D-6C5165E7DEFB]@0xffffff7f80bbb000->0xffffff7f80be6fff
dependency: com.apple.iokit.IONetworkingFamily(2.0)[59A00F6B-3710-3E07-9921-70C45782FF8C]@0xffffff7f80b5c000
dependency: com.apple.iokit.IOPCIFamily(2.6.5)[95ABB490-3AB5-3D5E-9C21-67089A9AE6A1]@0xffffff7f80821000
BSD process name corresponding to current thread: kernel_task
Boot args: root-dmg=file:///BaseSystem.dmg
Mac OS version:
Not yet set
Kernel version:
Darwin Kernel Version 11.0.0: Sat Jun 18 12:56:35 PDT 2011; root:xnu-1699.22.73~1/RELEASE_X86_64
Kernel UUID: 24CC17EB-30B0-3F6C-907F-1A9B2057AF78
System model name: iMac8,1 (Mac-F226BEC8)
System uptime in nanoseconds: 2914537178''
After this I change the RAM memory and use the "Apple Service Diagnostic Disks" (ASD Dual Boot 3S123), for make a test of all the computer and the computer pass all the test without a problem, so the Apple Service Diagnostic Disks says the hardware haven't problem.
So I think this is a software problem. After this I try to upgrade the EFI/Firmware with the "FirmwareRestorationCD1.3" and follow all the instructions for do that, but the computer never show up a blinking light or a sound, like the manual say, just delay the start screen, but never read the disk. So I can't upgrade the Firmware.
After this I try all the start up combinations, delete the NV RAM, start up in safe boot mode, in verbose mode and nothing happen. I try to start in single-user mode and show up the kernel panic message again:
efiboot loaded from device" Acpi(PNP0A03,0)/Pci(1FI2)/SATA(0,0)/HD(Part2,Sig00000000)
boot file path: \boot.efi
..Loading Kernel cache file '\kernelcache'…
root device uuid is 'EFCE0516-346E-3C93-AF07-630CB2C3AED1'
_
panic(cpu 0 caller 0xffffff80002c268d): Kernel trap at 0xffffff80002bd45f, type 14=page fault, registers:
CR0: 0x0000000080010013, CR2: 0x0000000000000018, CR3: 0x0000000000100000, CR4: 0x0000000000000060
RAX: 0x0000000000000000, RBX: 0x0000000000000403, RCX: 0x0000000000000001, RDX: 0xffffff80008b0dba
RSP: 0xffffff800081bd50, RBP: 0xffffff800081bda0, RSI: 0x000000000000013a, RDI: 0x0000000000000000
R8: 0x0000000000000010, R9: 0xffffff800081bcf8, R10: 0x00000000000fffcf, R11: 0x000000000000000b
R12: 0xffffff800081bf10, R13: 0x0000000000018e0f, R14: 0x0000000000000000, R15: 0x0000000000000000
RFL: 0x0000000000010056, RIP: 0xffffff80002bd45f, CS: 0x0000000000000008, SS: 0x000000000000000
CR2: 0x0000000000000018, Error code: 0x0000000000000000, Faulting CPU: 0x0
Backtrace (CPU 0), Frame : Return Address
0xffffff800081ba10 : 0xffffff8000220702
0xffffff800081ba90 : 0xffffff80002c268d
0xffffff800081bc30 : 0xffffff80002d7a3d
0xffffff800081bc50 : 0xffffff80002bd45f
0xffffff800081bda0 : 0xffffff80002c2b20
0xffffff800081bf00 : 0xffffff80002d840f
0xffffff800010beb0 : 0xffffff8000295c27
0xffffff800010bf00 : 0xffffff80006f7838
0xffffff800010bf40 : 0xffffff80006f6a66
0xffffff800010bf70 : 0xffffff80006f5cfb
0xffffff800010bfa0 : 0xffffff80002c6532
0xffffff800010bfc0 : 0xffffff80002b400d
0xffffff800010bff0 : 0xffffff80002b4359
Backtrace continues…
can\t perform kext scan: no kext summary
BSD process name corresponding to current thread: Unknown
Boot args: root-dmg=file:///BaseSystem.dmg -v
System uptime in nanoseconds: 0-907F-1A9B2057AF78 PDT 2011; root:xnu-1699.22.73-1/RELEASE_X86_64
I try with a different system installation and with the original one come with the computer and have the same problem. I start to think this is a Logic Board exactly the CPU problem, but If someone have another idea can help me I really will appreciate it...
by the way, sorry for the bad English, is not my native language.
Thanks for your time : )
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
I would disconnect the internal HD and with a bootable external or CD/DVD see what happens.
Does it boot up cleanly? If so the boot files are corrupted on the HD and you'll need to delete the partition and reformat the HD.
If you can't get it to boot the EEPROM where the firmware is loaded on has a problem. If you have access to the correct chip clip and a burner and access to the firmware file image you could try re-burning the firmware. Otherwise you'll need a new EEPROM or exchange out the logic board.
这个答案有帮助吗?
得分 0
4条评论:
I think the firmware is corrupted, so I try to re-install it, but cant, in the apple web page have some instructions, something about hold the power button for some seconds and I will see a blinking light or a sound, but this never happend... So if you know another way to re-install the firmware, that will be great
完成的
I have try to boot in diferent forms, USB, DVD, direct in the HD and diferents OSX but always the same problem, stop in the white screen with the apple logo, and sometimes the kernel panic message appear, like the image in the top of this page...
完成的
What Apple (and other manufactures) do here is burn the chip before they install it (pre-program it). If you have the correct gear you can do the same thing. The only trick is getting the raw image file. The EFI firmware installer has it encrypted within it so you can't directly extract it from it. People have extracted the image directly from a good working EEPROM and then re-burn that to the corrupted EEPROM or the replacement EEPROM they then install. The only issue here is you need to get the exact same model system to get the image from and you really need to alter the imbedded serial number (as you don't want to be a direct clone). Otherwise its time for a new logic board.
完成的
Have you tried going to an Apple Store to see if they can help you (without replacing the logic bd)?
完成的
添加一条评论
最有帮助的答案
Sometimes the AHT must be run in advanced mode 2 or 3x to find a problem - the problem might t only occur when the unit is hot or stressed.
Could be your new HD is too fast for the old unit. It has a 3GB/s SATA speed - new drives are twice that - many here have found problems where drives "claimed" to be backward compatible or automagic detecting were found not to be compatilbe or needed "manual" jumpering to work.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
1条评论:
I'm using the Apple Service Diagnostic Disc, and I run a lot of times, somethimes the system frozen, and i need restart it.
About the HHD I already set the jumper for 1.5/3GB/s and still have the problem, but thank you for your help
完成的
添加一条评论
Hi there, I had the same problem, then removed the ram memories, wipe his connections with an eraser, remove dust where memories go, put everything in place, lit the laptop and work normally.
这个答案有帮助吗?
得分 1
添加一条评论
I would say the MLB is heading out the door. In my experience when a iMac cannot boot into any system internal or external it usually has to do with the MLB. HDD speed should make no difference.
这个答案有帮助吗?
得分 0
2条评论:
I see, but why the Apple Service Diagnostic, cannot find the problem. And if the MLB have the problem, why this happened?
完成的
If you look in the crash logs you may find why the system froze/crashed. Because you "crashed out" of AHT it never gets to report what it finds. Not every repair is a DIY repair! Looking at your timeline and current problems replacing the logic board (if you feel it's economically feasible) would be my solution.
完成的
添加一条评论
添加你的答案
Chavira 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 31,126
