跳转到主内容
MacBook Pro带有15寸屏幕的型号
8443 个问题 查看全部
What is this burned part on my logic board?
I have a 15" MBP a1286 2.66GHz. Today when I plugged it in after not using it for months, and pressed the power button, I noticed that it was getting very hot at the bottom of the case. I unplugged it, took out the battery and pulled the buttom case. I saw that a small chip to the right of the memory slots had burned up. It's indicated by the arrow in the picture below. I'd like to know what this does, and if it indicates a problem elsewhere in the system. If I replace the logic board, will I just cook another one? Also, the cable below that chip was not fully seated.
This is kind of a monster computer that I built from two broken ones, so it's not really a surprise that something like this happened, but I would like to get it going again. However, I don't know enough about the logic board to know if this indicates a problem with some other part that will effect my new logic board if I put one in.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
评论:
RoggeSound, just to make it easier, could you post the last three digits of your serial number, or the 820-XXXX number of your logic board? this will help to properly identify your logic board.
完成的
Logic board number is 820-2532-A
完成的
Had this computer (or either of the ones combined to make it) even come in contact with water? It almost looks like there is water damage on it from they way I am looking at it.
完成的
Yes, they were both damaged in a flood, but the part in question was not burned up when I built the computer. Even now, when I plug in the power adapter, I can feel that part getting hot right away.
完成的
添加一条评论
1个回答
已选择的解决方案
RoggeSound, that is part of your PBus Supply & Battery Charger circuitry, reference designator Q7030 which is a Silicon N Channel Power MOS FET RJK0305DPB LFPAK-HF and is available at places like this. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
评论:
Thanks! I just bought a few of those to try to replace it and maybe save this logic board... logic boards are really expensive if you didn't actually pay for the computer. At least this way I'll only cook a $2 part if this isn't the underlying problem.
完成的
That's the way I like to look at things. If it is only a few $$, why not try;-) thanks for accepting my answer.
完成的
添加一条评论
添加你的答案
RoggeSound 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 767
