跳转到主内容
The BlackBerry Bold 9900 is a smartphone with full QWERTY keyboard and touchscreen.
25 个问题 查看全部
Replace a faulty keyboard key or full assembly
I have a faulty return key that seems to get stuck with the lightest touch. I would like to either remove the key to see what the issue is, or replace the keyboard assembly.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
4个答案
已选择的解决方案
check out this free guide to see if it can help..it's pretty easy to either clean the keyboard of any gunk or replace the keyboard assembly.
这个答案有帮助吗?
得分 5
1条评论:
Good find. I also found this video break down.
I purchased a new keyboard/touch pad assembly for $10 from ebay and will attempt the replacement as soon as it arrives.
完成的
添加一条评论
no work
这个答案有帮助吗?
得分 0
1条评论:
ali, try to ask a question with more than two words. What does not work? What is not working? What have you tried? The better you explain things the greater your chance of getting a meaning full answer.
完成的
添加一条评论
middel row alphabet is not working
这个答案有帮助吗?
得分 0
添加一条评论
My whole keyboard is not working anymore. Opened it once just to check inside, but it just made it worse. Previously I only had a few keys not working, now I have almost the whole keyboard.
I think it might be related to the ribbon cable, or even the plug for it on the motherboard. I hope not though.
Know where I can find a new keyboard ?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Neil Cuthbert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 12,121
