iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1501 个问题 查看全部
PUK IS LOCKED How do you unlock it.
My iphone 3g is locked. My daughter couldn't remember password & after so many tries she locked herself out. The phone is used for playing games & getting on wifi. It has not had service in years. I can't even access itunes because I can't remember that password & I;ve deleted the email I had it set up for. So is there any other way to get it unlocked? I'll try anything at this point but I don't want to go to Apple & pay money. Thanks Doc
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 3
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
Doc, place it in DFU and restore under iTunes, preferably the same computer that you normally use to sync it. This should eliminate the password issue, but you may lose all the data on the phone, unless you restore on the computer that you normally use. you could also try this. Hope this helps, good luck.
这个答案有帮助吗?
按维修分数 3
添加一条评论
添加你的答案
Doc 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 5
总计 1,034
