跳转到主内容
摄相机和Go Pro以及监控的维修指南
406 个问题 查看全部
The moisture warning is on permenantly.
The moisture warning on my Panasonic CamcorderNV-DS65EN is always on, even when the camera has been kept in a warm, dry environment for 24 hours. I suspect that the moisture sensor has failed, but have no idea where in the camera it is fitted and what disassembly is necessary to reach it. Replacing it would be no problem if only I could find it!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Electronic moisture sensors have to be exposed to the air somehow, the ICs often have a small cut in them with a felt window that looks similar to what you see on a small microphone.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Graham S Dawson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 590
