跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2519 个问题 查看全部
iPhone 5 not charging or connecting to iTunes
So, i bought an iPhone 5 last week, the seller told me everything was working except the logic board. When i got it i did a soft reset and it booted up, it showed 10% battery. After the battery drained i tried to plug it to my computer and no response. Same with wall adapter. I replaced the dock connector and the battery and still no response. The phone boots up and functions perfectly but doesn't recognizes the lighting cable or any kind of power inlet. Any ideas what could be causing the problem? (I've heard something about the USB Power IC, but not sure about that). Thank you in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The logic board is the motherboard controlling the entire phone. Try Changing the lighting port and if that works, you are blessed.
这个答案有帮助吗?
得分 1
2条评论:
Wisdom Banks, "replaced the dock connector" includes the lightning port
完成的
Thanks for your respond, it turned out it was the motherboard, I sold the iPhone and bought a new one. I did change the lightning and the battery with no luck.
完成的
添加一条评论
添加你的答案
Luis Fondeur 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 778
