computer does not recognize airport card.
My laptop ws working perfectly recieving internet connection until I tried to clean out the junk on my Hard drive.
Now, when ever I try to connect and set the computer on airport connection, it always goes to the internal modem setup and I cannot delete that configuration. Did I loose sometihng of the apple program that is needed to select the port of the airport connection?
Would the only solution to fixing the problem b to erase the hard drive and reinstall the system again (which I forgot to mention is Mac OS 10.4.6) If this is the only solution would I loose everything on my hard drive?
I await your reply. hope I've given you enough of an explanation to help you to help me. Thanx Curt
1条评论
Airport port connection
由 clc 完成的
