None of the methods on this page worked for me - all of the suggested changes were already properly set. Turning them off and back on did precisely nothing too. But sometimes turning the settings back and forth won't take unless the confused device is restarted at a crucial part in the process, so here is what I did which finally fixed it for me:
1. Turn the notifications OFF in the app settings: (pull the notification area down > touch the gear icon to open Settings > More > Application Manager > All > Messaging > Show notifications (uncheck it)
2. Restart the phone
3. Send yourself the message and before it arrives, immediately exit the app by repeatedly hitting the "back" soft button (you need to do this fast – as soon as you hit Send). You should NOT receive the notification at this point.
4. Restart the phone
5. Send yourself another message and before it arrives, immediately exit the app again. You should still NOT receive the notification at this point, but by now you will have forced the phone to accept your own "notification off" setting (I love reverse psychology)
6. Restart the phone
7. Turn the notifications ON in the app settings: (notification area gear icon to open Settings > More > Application Manager > All > Messaging > Show notifications (check it)
8. Restart the phone again (I know, it's a pain in the keester, but it's all in the restarts)
9. Send yourself yet another message. Again, before it arrives, immediately exit the app. At this point I did receive the notification, but if you do not, restart the phone one last time and try texting yourself while doing the whole bailing-faster-than-a-hamster shimmy.
IMPORTANT: The native texting app won't notify you of incoming messages when you have the thread open (even with the notifications on – that's a default behavior as there is no point in notifying you about incoming messages while you're looking at them). That is why you need to exit the thread BEFORE the text arrives by hitting "back" (home button might not be enough to do the trick). So if you are still not receiving notifications, make sure it's not a simple case of staring at your own thread while receiving your own texts.
11条评论
Most of the requirements for long-term use of the building original appearance. In determining to choose the type of stainless steel, the main consideration is the aesthetic standards required by the system to be used to clean corrosion and atmospheric location. However, a growing number of other applications just to seek completeness or permeable structure. For example, industrial building roof and side walls. In these applications, the owner of the construction costs may be more important than the aesthetic, the surface is not very clean may be.[url=http://www.jawaysteel.com/]Stainless Steel Metal Products For Sale[/url]
[url=http://stainlesssteelmarket.com/stainles...]Stainless Steel Cold Rolled Heat Treatment[/url]
由 veevee123 完成的
Audible notification for Message+ on Galaxy S8 stopped working yesterday 6.17. All settings are correct and volume is up. Reboot did not help. Previous comment above (re: building?) is not coherent with this thread. Has anyone else experienced this issue?
由 Richard Grenier 完成的
My s7 notification text sound is not working help
由 Cary Briggs 完成的
I too, had the No Notification issue with my S6. Until I notice that in Settings>Notifications>Messages> Show Silently was some how turned ON. I believe it happened on my last UPDATE. Once I turned that OFF it work..Hope this helps.
由 Wry_Rick 完成的
I also have had this issue with my J3 for months and just took the time to figure it out. Like the above I had the notifications on in messages. I discovered through Facebook messenger my notifications were off. I clicked and it took me to phone setting for notifications. All were turned off, surely something I did at some point. Anyway I went through and changed all apps that I did want notifications from and that solved receiving sounds for FB,messenger, emails etc.
由 Chris Henson 完成的
显示更多的6条评论
