iPhone doesn´t charge even after repair it
My iphone 4 was charging very slow (10% by hour) and it didn't detect that its plugged, so I thought "May be the battery was dead", so I replace it and it didn't change. After that I decided that the dock connector is the problem, so i replaced it but the problem persist.
Maybe something on the logic board is damaged?
3条评论
Like Vincent Monteil says, try a different cable as well as an AC adapter and see if that makes a difference.
由 oldturkey03 完成的
I've tried with lots of cables even with a 30-pin to RCA and it doesn't stream video or audio
由 jimenezser 完成的
Have you checked the charging coil and components?
由 oldturkey03 完成的
