跳转到主内容
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 个问题 查看全部
My iPhone keeps rebooting after water damage.
I have an White iPhone 4 CDMA that fell into a pool for about a minute. That person kept it for a week trying to dry it by taking off the back and drying it with a towel. Then after the week, he gave it to me and I tested it's functionality. It booted when plugged in and the battery as completely dead (it doesn't charge). It said 100% Plugged in on the phone. It dies after like 4-5 minutes of use while plugged in. It's normal functions don't work with dead battery. I tested it with a working battery and it displays the battery percentage right and also dies after 4-5 minutes of use. It works completly fine and then it shuts down. When it shutdowns, the LCD dies out slowly. Like if someone unplugged the battery. Then, I took it completely apart and cleaned the motherboard and other cables thoroughly with isopropyl alcohol. The phone does the same with dead battery. This time it show 2% and does the same. I am going to test it with the working battery later on tomorrow. Is there any way to stop the iPhone from rebooting?
UPDATE:
The battery sorta works. It only chargen to 12%-14% and it does. But it works. It just keeps shutting down by it self.
NOTE:
It has been tested with a new battery and it still shuts down after about 2 minutes of use.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
It seems that your battery is damaged, so you need to replace it.
完成的
Have you checked the battery connector solder pads, The charging coil and the IC? Is your phone recognized by your computer? Have you tried an AC charger yet?
完成的
添加一条评论
3个答案
最有帮助的答案
The phone is rebooting cause the battery is wrecked buy a new one an that will sort it out!
这个答案有帮助吗?
得分 1
1条评论:
It just shuts down. The screen fades away and just dies (as in the device fails to stay on and shuts down). Even with working battery.
完成的
添加一条评论
You need to check with a multimeter if you have these connections! ( Continuity )
http://2.bp.blogspot.com/-yryfuj6t6cM/UO...
Update
Yep but i said that you need to clean the phone with 97% alcohol! Alcohol vanishes but cleans the phone.
Trust me , iv done it alot of times!
这个答案有帮助吗?
得分 1
2条评论:
Also , did you clean the complete Iphone with alcohol? Also removing the iron covers? After cleaning , let it dry in for example rice! It drains out the water :)
完成的
http://www.imore.com/have-liquid-damaged...
As per the above article these things can damage the iPhone even more.
完成的
添加一条评论
Yeah I had that problem too. You need a new battery. Replace the battery using the guides on this website and that problem will be fixed. However, there might be more problems with the device so be prepared
这个答案有帮助吗?
得分 0
1条评论:
It's not a battery problem. I used a new battery before and after cleaning it with alcohol. It still has the problem with it just fading away
完成的
添加一条评论
添加你的答案
Alfonso Torres 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 6,907
