跳转到主内容
非一体化电脑称之为台式机。
2132 个问题 查看全部
"no signal" message on monitor
My PC is running on Windows 7. While using pc, it abruptly shows "no signal" on monitor. going out of control. Even If we press reset button also, it won't reset. Forcebly, switch off the system. What will be the problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
MadhuSudhan Rao, not sure what you mean by "going out of control". It is entirely possible that you either have a bad video card, which may stop sending a signal, a bad cable/connector from the monitor as well as a bad video board in your monitor. Check the monitor on a different computer. If it works without a problem. you know that it is not the part that is failing. run Windows in safe mode and see if that makes a difference. If it does, you know it is software (most likely settings) related. If it does not make a difference, replace your video card. It will also help if you tell us what make and model your computer is, as well as what video card you are using. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
MadhuSudhan Rao 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 968
