跳转到主内容
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
90 个问题 查看全部
Wireless 360 controller met its demise via cup of tea
Hi there as listed in title I have had an accident with Xbox 360 wireless controller and a cup of tea and now it will not turn on or charge or anything really. I have split open and tried to clean insides buttons, board etc with cotton buds and alcohol gel best i could which has got rid of the stickyness and loosend up buttons but still nothing happening power wise ie won't turn on light up or charge , is there anything I can do to try and fix it or is it a case of buying a new pad? Cheers
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Ok thanks ill give it a try would the gel not be sufficient for cleaning then
完成的
No, sorry not sure about the gel stuff, but can't use it to clean.
完成的
添加一条评论
1个答案
已选择的解决方案
Anthony, clean it properly with 90%+ isopropyl alcohol. Use a small brush to clean it properly and do not forget the connector and cable ends. Check for any burned or charred components. Do not use it until properly cleaned. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Anthony 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 151
