跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
1269 个问题 查看全部
My iPod wont play out loud. Any ideas?
it will play thru earphones and speakers but not on its own.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
已选择的解决方案
Jo Boyle, it is possible that you have a stuck audio jack, it may believe that the head phones are still plugged in, even if they are not. Try to clean the jack with a few drops of isopropyl alcohol and either a vacuum cleaner or a some puffs of compressed air. If that does not work, you may have to replace it.
这个答案有帮助吗?
得分 0
评论:
thanks, have already tried jacking/unjacking earphones several times & blowing into jack. Its still under warranty so think it will have 2 go back.
完成的
添加一条评论
Did you open it up? Sometimes if you are not careful you can damage the speaker.
这个答案有帮助吗?
得分 0
评论:
No, not been opened up, but thanks for the tip.
完成的
添加一条评论
添加你的答案
Jo Boyle 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 790
