跳转到主内容
The Nokia N8 is the first device to run on the Symbian^3 mobile operating system and Nokia's flagship device of 2010.
20 个问题 查看全部
detects only 3G signal but doesn't read 2G signal
My N8 which I got it from Canada with Rogers network, worked well for an year. Then suddenly from one morning onwards it doen't receive or detect 2G signal.
It works and detects only in 3G signal area. All the tips and tricks had been followed but no use. I took it nokia care and even they couldn't fix it and the reason they said was that I am using it in India but not in canada. So, they couldn't fix it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
1st clean the antenna conector, if not working replace the bottom cover assy because there is the pads for the antenna, if still not working you need to jumper the internal antennas and for that you gonna need someone with technical knowledge...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
madivada sriramanuja 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 539
