跳转到主内容
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
146 个问题 查看全部
LCD Backlight out after liquid spill (A1377)
Spilled tea (no sugar!) on my girlfriends Macbook last night. Took it apart today and cleaned everything with first 70% then 99% isopropanol.
There was very minor corrosion in a few spots, notably the screen connector.
Today managed to get it to boot and backup in time machine (she had no backup!) However the screen is very dim, I needed to use a headlamp to read it and even so it is difficult.
There was one similar thread (Liquid spill results in extremely dim screen, how to fix?) with no conclusion. I understand some macbooks have a fuse for the screen? Is this the case with the A1377 model and where is it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
6条评论
Attach an image (or two) of your logic board with your question. That way we can see what you see and can possibly point out the fuse.
完成的
image added! there is a part similar to the fuses described in other posts, a brown or orange smc with an N on it. It reads 8.3v on both sides though.
完成的
chris, what are the last three digits of your serial number? Trying to match up the proper schematic for your computer....
完成的
Serial number is c02dxhnhddr1. If the fuse is indeed the part in the image you have attached, it is OK. Do I consider replacing the led driver?
完成的
These are the specs according to your serial number. Does that look right ;-)
1.86 GHz Core 2 Duo (SL9400)
Intro Date: October 20, 2010 Disc Date: July 20, 2011
Order No: MC503LL/A* Model No: A1369 (EMC 2392)
Subfamily: Late 2010 Model ID: MacBookAir3,2
Std RAM: 2 GB Std VRAM: 256 MB
Std Storage: 128 GB, 256 GB Std Optical: None*
完成的
显示更多的1条评论
添加一条评论
3个答案
最有帮助的答案
The FET is never the problem, don't go shorting things without knowing what is going on.
Do you get 8v, 0v, or 27v at pins 3 and 4 of the LCD connector?
Issue can be full 27v is there but a burned out screen, 8v is there unboosted, or nothing is there at all. Common issues are burned feedback via to LED driver, blown fuse, burned BKL_EN resistors, shorted cap on boost line.
Also measure for a short to ground on backlight output.
No guessing and no shorting is allowed here, only measuring, analyzing, and learning prior to fixing the REAL problem!
这个答案有帮助吗?
得分 1
添加一条评论
chris, the fuse is reference designator F9800 and is a 2AMP-32V 0402-HF. All you have to do, is to check the fuse for continuity. The LED driver is right next to it, and that can most certainly give you problems as well. Once we have your serial number we can hopefully identify the logic board number and get you more details of the schematic. Hope this helps, good luck.
Update
Thatnks for the serial number. It allowed me to verify that this is the right fuse. The driver next to it, is reference designator Q9806 and it is a FDC638APZ SBMS001 Mosfet P-Type RDS(ON)43 mOhm @4.5V and LOADING 0.4A. You can get it from here if needed. I would suggest that you get the datasheet and measure that FET first.
这个答案有帮助吗?
得分 0
添加一条评论
Any comments whether replacing that FET is likely to fix the problem, given shorting the output of the FET does not?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 3,409
