跳转到主内容
The Motorola Xoom is an Android-based tablet computer by Motorola, introduced at CES 2011 on January 5, 2011. It is the first tablet to run Android 3.0 Honeycomb.
43 个问题 查看全部
Lost power won't power up
I accidentally plugged a phone charger in one of the other ports. When I did screen went black. No it's not powering up. The battery indicator led lights white then turns green. But will not turn on at all. I hope it can be fixed.
Thank you
Lee
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
Try to reset the device? vol up + power.
If it does not work you might need to open the device up and see whats damaged.
这个答案有帮助吗?
得分 0
1条评论:
Thank you I tried the volume up and power button. No go.
完成的
添加一条评论
Thanks it worked on mine.
这个答案有帮助吗?
得分 0
添加一条评论
Thanks so much! Worked on mine as well.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 696
