跳转到主内容
alarm not stoping, had to disconnect the battery
my car (Honda accord 2004 EX) was vandalized and all the control units were removed. i need to get the car in for replacement but the alarm wont just go off even when i start the ignition. dont know if it will eventually go off if i leave the ignition on ...or move the car. i need a quick fix.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I don't have any specific experience with this problem but you can try these:
Remove the alarm fuse. You should be able to look at the owners manual to locate the specific fuse, if there is one.
Disconnect the car horn (assuming this is the source of the sound). This won't stop the alarm from activating but will silence it. This solution can drain the battery too.
Disconnect the battery while the car is parked.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
prince 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 9,216
