跳转到主内容
Wanting to replace my inverter cable
Hello, I have had a problem with my screen going black yet the machine is still running. After a lot of reading I have come to the conclusion that it is my inverter cable. Is there a guild on replacing this cable anywhere?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Sarah, the mid 2009 does not have an inverter cable because it does not use an inverter per se. It uses LED backlight technology and as such uses a LED Driver board. If you can give us the last three digits of your serial number, it would allow us to properly identify your computer, and to help you a bit more. Anyhow, check this LED Driver and on here for the How To. This may of course change once we identified your computer better. Hope this helps, good luck.
MacBook Pro 15" (Models A1226/A1260) LED Driver Board图片
产品
$44.99
这个答案有帮助吗?
得分 2
2条评论:
Thats what I was thinking too - OT
完成的
Great minds think alike :-) and it does show the importance that the OP properly identifies the device in question :))
完成的
添加一条评论
Is this what you're looking for: Installing MacBook Pro 15" Core Duo Model A1150 Display Inverter
这个答案有帮助吗?
得分 1
2条评论:
thank you for your reply. for some reason it has said i have the older macbook, the macbook pro i have is the mid 2009 15", i did look at this guid but it didnt help me :(
完成的
Can you give us the last three digits of your serial number so we can see if we can better ID your system. Are you sure its the cable and/or inverter? Does an external display work when connected? If no then you have a GPU problem.
完成的
添加一条评论
添加你的答案
Sarah 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 169
