跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Why is my backlight on, but not my screen?
I am attempting to repair a friend's iPhone 4s to no avail, and I need some help. I have restored it in an effort to rule out software malfunctions, and have installed several screens which appear to be in working order, however the screen continues to be blank, although the backlight is working on each display when it is attached. The phone appears to be in good working order, but for this one small error (it is recognized on a computer, holds a charge, etc). Here is a link with a picture of the one abnormality I have located thus far - a screw socket is missing on the main board near the display connectors https://docs.google.com/file/d/0B6WmvtP7...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
you probably didn't take out the protector covering the LCD when you got the new screen. hopefully this will help you
这个答案有帮助吗?
得分 0
添加一条评论
Ryan Hoffman, check the component pointed to by the red arrow. On your attached image, it appears to be damaged. Use a multimeter to check it for continuity. Also, take a closer look at the area outlined by the black rectangle. There are a few SMD components that may have gotten damaged. Of course, all of this may just be based on my poor eyesight:-)
这个答案有帮助吗?
得分 0
1条评论:
Hi did you get this problem sorted, I have the exact same problem and damage to 4s Logic board.
完成的
添加一条评论
添加你的答案
Ryan Hoffman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 247
