跳转到主内容
所有适配器的维修指南
20 个问题 查看全部
Battery Charger to hel test if it's a bad battery or a bad power jack
I do computer repair. I was wanting to know if they have a device that can charge any laptop battery externally. In my troubleshooting I want to make sure I'm not dealing with a bad power jack that's not charging the battery or not charging it right. I want an external device to determine if I'm just dealing with a bad battery that needs to be replaced.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Good question! Sorry no.
The problem here is each different LiOn battery requires a different charge cycle & connection just within the one manufactures collection of systems it sells (Apple alone is around 20 different batteries).
这个答案有帮助吗?
得分 1
1条评论:
The best way is to use a Ohm meter to check the connectivity, and a Volt meter to check the voltages of the circuit pathway.
完成的
添加一条评论
添加你的答案
Dan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 231
