How to tell if your iPhone is AT&T, Verizon, etc.
It is stuck on the activation screen, so I can't go through settings to find it.
Turn it over. If the model number is A1428, then it is an AT&T or T-Mobile phone. If it says A1429 then it is a Verizon or Sprint one
IMEI or MEID is available on lock screen. IMEI is for A1428. Enter the IMEI or MEID in the carrier website to determine the carrier
这个答案有帮助吗?
So if my iphone says A1429 can I use it for verizon and sprint
Mines LGMS631 what do i have???
what about A1533?
my iphone has A1533 is that at&t??? @tomchai
A1533 is iPhone 5s CDMA/LTE, it is not possible to tell which carrier it is for using the model number.
Here is a complete list from Apple on all iPhones and model numbers.
这个答案有帮助吗?
Actually, this page does not really tell you which models assigned to which carriers. You will basically need to do some googling if you want to find this info since after each new iPhone release there are plenty of publications on cNet and other tech websites that would point which models are sold by which networks. I bet if you even simply google your model, you will get a result with the carrier who was selling that model.
@andy888 I didn't say it was. I simply said it was a comprehensive list of all iPhones and model numbers from Apple.
Actually if you have an iphone go to settings/general/about it gives you the network you are on and the model and serial number of your phone.
Actually, in most cases, it is impossible to tell which carrier the iPhone is or was used on by simply looking at the model number. Though in some cases it might work. There is actually an IMEI check which can show what is known as the "Initial Activation Policy" and this would be the original carrier of the device. Notice however that the same device can be used on another carrier later.
这个答案有帮助吗?
imei.info will tell you the carrier it was sold to.
But in the US if the model has 2 available (GSM and GSM+CDMA), GSM only are sold to Tmobile/AT&T, and Verizon and Sprint get the other model.
To find what carrier network it's locked your iPhone, Verizon, T-Mobile or AT&T, you can do this using iPhone IMEI Checker service. You need to find your IMEI number from your Cell Phone, and go here iPhone IMEI Carrier Checker to find the full informations for your device.
这个答案有帮助吗?
Have you tried the iphonedata.info? I heard they are free.
Yes, they are free but only can tell you what model is your iPhone. If you like to check SImLock, Carrier Info or iCloud Status then will need to pay on them.
If like to find what carrier network it’s locked need to use some official IMEI checker from AT&T or Verizon company. Then can see. Or if not know need to use GSX Apple IMEI checker
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 98
总计 55,359
4条评论
Please Help me as my husband recently passed away and I cant think straight. I purchased Straight Talk, and I want Verizon as my service, as it is the only service that works in this little town
由 ladywadefisher 完成的
my iphone says a1332 is it at&t
由 josmar 完成的
That is an iphone 4 on the GSM network.
由 Wade 完成的
I have an iPhone 6 through straight talk, how can I find out what carrier it goes through?
由 Ed Gorney 完成的
