跳转到主内容
The second iteration of Samsung Galaxy Tab tablet computers with a 7.0-inch screen. Model numbers: GT-P3105, GT-P3100, and GT-P3105.
125 个问题 查看全部
Why won't my Samsung Galaxy Tab 2 7.0 turn on?
I was in the middle of checking Facebook when my tablet randomly turned off despite being fully charged. I left it charging for more than 3 days and still nothing. I tried holding down the buttons and even connecting it to the computer to see if my computer would recognize my tablet, but still nothing. Can anyone give me some tips on what to do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 114
67条评论
same thing here i was on a game and it just turned off
完成的
When I came back from walking the dog , it wouldn't turn on.
完成的
Just happened to mine too. Should be fully charged. Screen is black but twice when I hit the screen it made a ping sound but didn't turn on. Can someone help, please?
完成的
My Samsung galaxy Tab 2 7.0" ran out of battery so I left it for a few days, forgetting to charge it.. Now it wont turn on. I've tried holding down the power button and the volume up button for 30 seconds but still nothing? what do I do?
完成的
Same I need a fix
完成的
显示更多的62条评论
添加一条评论
32个答案
最有帮助的答案
Try the following; it has worked for me well.
Press & hold "Power & Volume" buttons at the same time for 15 seconds. Then it will turn on without any issues.
这个答案有帮助吗?
得分 70
64条评论:
ya..it worked out.Thanks a lot.
完成的
I press and hold the Power and Volume buttons together for 10 seconds.Then it turned on.And again it went off.But I repeated the same for another 5 seconds.Then it turned on.Thank you.
完成的
Did not help. Nothing happened. Tablet did not switch on :(
完成的
OMG!~!!! I LOVE YOU!!! I thought my poor tablet was gone forever!!! Thank you
完成的
It didn't work..... when I followed what u said .... it turned on but the screen completely frozed
完成的
显示更多的59条评论
添加一条评论
Hold the power button and volume up button for thirty seconds while plugged into a computer.
这个答案有帮助吗?
得分 19
22条评论:
Thanks it helped a lot
完成的
I did this but did not plug it into a computer, just a power source and it totally worked! Thank you!!!
完成的
Mine just had the same problem last week. This trick really helps. It's coming up now. THANKS A BUNCH.
完成的
worked like a charm bro
完成的
It worked for me . Thanks a lot
完成的
显示更多的17条评论
添加一条评论
My problem was that I could not turn on my Samsung device no matter what I tried. After few hours of trying, I found something that might help you. I connected my device to the charger and waited a few minutes. Then I pushed volume+ and the power button. The screen turned on, and it started charging in the Samsung "charging screen."
This problem is very common on Samsung devices. You can prevent this by regularly charging your device. DO NOT LET IT TURN OFF BY ITSELF. Factory reset your device every 3-6 months.
edit: sometimes your device might think that it is charged when it is really not, so i recommend ether doing the factory reset or getting an app that cleans and refreshes your device.
这个答案有帮助吗?
得分 11
5条评论:
thank you sooooo much my tablet is up and charging again as i haven't used it for about 5 months now thanks again.
完成的
Not sure why my Tab 3 stopped. had a full charge, was out side burning a cigarette...it is so very hot here well into the high 90's with humidity to match, ...so, as I was saying, I was smoking and it was on- I was outside maybe 5 minutes. My home has central air conditioning, it's at about 66 ish inside...the next thing I know it's shut its self off and will do nothing. I waited for hours and still nothing...then I found this rather long post, I tried the volume up and power on, at same time and holy crap it came on...wowza. Thanks for spreading your wisdom.
完成的
it worked now its charging
完成的
Thanks for the advice but still no joy!!
完成的
thanks a lot. you just saved me some serious money. It worked for me.
完成的
添加一条评论
1 unplug the charger.
2. press and hold the power button and volume up button for 35sec.
3. put the charger fast in the port and press and hold the power button and volume up button for 35sec again.
4. leave it to charge. amazing!!!!!.it work whiles charging.
note: please don't let it go off by itself...charge regular
your feedback is allowed, iamkoomson@gmail.com
这个答案有帮助吗?
得分 9
8条评论:
thankyou so much this worked for us! had tried everything else, literally, it is currently charging so hope it continues to! :)
完成的
thank you, i´ve tried everything else and did not reboot, now after this it turned on :)
完成的
Didn't work for me..i will keep trying to get it to boot on...it keep showing the battery charging but it has been doing that for a couple days.
完成的
That is exactly what mine is doing. Any suggestions?
完成的
Thanks a million, it worked & will have a happy child this evening.
完成的
显示更多的3条评论
添加一条评论
Happened to me too with about 60% battery. Pinterest locked up and all of a sudden it was the black screen of death! Nothing from it until I plugged it into my PC and then just a battery flash. Took at least 5 minutes for it to respond with a Samsung flash. I kept trying the power button and the up volume and it finally booted up!
这个答案有帮助吗?
得分 6
4条评论:
Exactly how much time did it take to get booted up because mine got a flash of battery than no response
完成的
my did not work h
my was 60 befor it turn off and if i try to turn it on it wll show samsungn gos of pls help
完成的
Nothing seems to get my Samsung tablet to work again.try to whole the button nothing try charging for more then a few hours.could it be that my tablet was not charge for 2 weeks because I had to replace my charger.maybe battery dead.don,t know how to open the back.could some please help me.it blinks but never come back on.
完成的
My Samsung galaxy tab 750 won't turn on after displaying “ Format this device “ and I failed to do so.
I've tried all the means but still won't turn on.
完成的
添加一条评论
Get a needle and charge the tablet, then use the needle to press the reset button on the top left side of the tablet and voila there you go a working tablet
这个答案有帮助吗?
得分 4
4条评论:
!&&* no it didnt work!!!!
完成的
that is not a reset button that is the mic....
完成的
Thank you. This worked instantly on my Tab 2 7.0
完成的
完成的
添加一条评论
Same thing with my Galaxy Tab 3. Instead of holding power/volume buttons simultaneously, removing sim/data card, prying off back, plug into power source, etc. etc. etc....I tried this;
- turn unit face down. Place in dirty catbox. With left foot, place firmly on back of unit and slide back-and-forth through dirty catbox.
- remove unit with salad tongs & place face-down in toilet bowl. Let float. Watch one quarter of NFL Football on Fox. Return to toilet bowl. Urinate on floating unit. When finished, have someone else remove unit from toilet.
- have someone hold unit like a football on a kicking tee. Stand back two paces, then step in one motion towards ball. Kick unit like extra point towards front door. With front door open, pick up said unit . Turn said unit on side, elbows out, bring arm back - and with one motion, fling unit out front door, over hedge, skidding across pavement into road.
- return to your regulary scheduled bad habits.
Hope this helps. It worked for me.
这个答案有帮助吗?
得分 4
1条评论:
"holy smoke and mirrors batman"" not only was this post funny, but darn it worked ***NOW BACK TO THE GAME**
完成的
添加一条评论
Same thing with mine! Help please! Just downloaded the owner's manual to look at troubleshooting, total waste of time! All it gives you is:
Troubleshooting
If your device has fatal errors, hangs up, or freezes, you may
need to reset the device to regain functionality.
• If your device is frozen and unresponsive, press and hold the
Power/Lock Key for 10 to 15 seconds.
Thanks Samsung for nothing!
这个答案有帮助吗?
得分 2
3条评论:
thanks ! i got it on
完成的
tnx 4 d info...it works...
完成的
It doesn't work
完成的
添加一条评论
The only one that worked for me was the back off and disconnect the battery for 15secs
这个答案有帮助吗?
得分 2
1条评论:
I blew into charger input also cleaned by blowing charger plugged it into my laptop and held power button and the volume button down not up Came back on with no problem good luck people....
完成的
添加一条评论
Hey, I was having exactly the same issue. Did all of the above button holding tips. Took about 5 attempts but eventually it worked and started charging.
这个答案有帮助吗?
得分 2
添加一条评论
A common problem Galaxy 3, and in Note 2 same components as tab 2
EMMC component (memory module) all information on the phone was lost.
  There are labs that can repair and replace the component in the new one, a better version of the component
you can read about it
note 2 sudden death
这个答案有帮助吗?
得分 1
添加一条评论
Model: SGT P100
First, remove the SD Card and sim card. Press the Power button +Volume Up at the same time for at least 10 seconds. Release the power button when the Samsung logo pops up, but continue to hold the Volume Up until the recovery screen appears.
Use the volume buttons to navigate the menu and select one from the four options as indicated on the picture above, press Home to choose the selection. I suggest that you simply reboot, this alone might do the trick.
The said procedure resurrected my tab:) Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
Similar problems here: screen blacked, then refused to charge, would attempt to start but then the screen faded to black.
I followed the above instructions - restart button plus volume up - I got a green android icon with, what appeared to be its guts open (!!!). Selected 'factory reset' and it then went through a process of about 5 minutes of reconfiguration. I lost some photos and needed to reinstall some apps.
I think this was a good outcome, and an easy DIY fix.
Still love my Samsung!
这个答案有帮助吗?
得分 1
添加一条评论
It is totally due to the power disconnection. This occurs due to the disconnected power source. This issue can be resolved by put the tab to the power source and press both volume down+power button. This can solve your issue. By chance if this press can’t work then reply to this content or visit https://cowboypaper.com/essay-help/
这个答案有帮助吗?
得分 1
添加一条评论
I got the back off and pulled out the battery. Left battery out for an hour. Put battery back in. Left power off and plugged into charger. Is currently charging and turned on. We will see if this fixed it completely.
这个答案有帮助吗?
得分 0
1条评论:
Hazel Tom, I had charge my Samsung Galaxy Tablet 3, I hold the home button, the down button and the power button, the Android came on, what do I do
完成的
添加一条评论
hello and perhaps gone the battery, but you can try to scaccare pin battery, then press the power button like you have to turn on the fact that, reconnect the battery and test if it comes on sometimes works
这个答案有帮助吗?
得分 0
添加一条评论
Heya .I was also playing agame when it happened . not sure why it happend however i was looking for help while i was leaving it in the fridge for 1 min(to cool down) then i had it with me under my blanket(to warm up ) . i booted it and it worked.
P.S. make sure u dont let it get too cold or hot , will dmg system . also make sure it is enough or nothing will change ...
这个答案有帮助吗?
得分 0
添加一条评论
This can be resolved by leaving your Galaxy Tab to charge over night. If you let the battery run too "dry" ie. if you haven't used your table for a long time (6 months or more) the battery requires a long time to charge up. My tablet wasn't showing ANY signs of life before 2-3 hours of charging up, then it woke up and is now been working normally ever since.
这个答案有帮助吗?
得分 0
添加一条评论
hello home more volume button on most ignition resetare factory but if you have a custom rom (home more volume in June on and you put it in bootloader and then flash with odin not forget to do a reset after it flashed risk could crash
这个答案有帮助吗?
得分 0
添加一条评论
Try this. Plug in your tablet as if recharging using the original charger. Hold down the power and sound buttons simultaneously and keep holding for at least 20 seconds. Should show the recharging icon. Works for any Samsung tablet
这个答案有帮助吗?
得分 0
1条评论:
It did that but after showing that the tab is charged 100%, I turned it on but it just showed the black screen and went off. What to do in this case? The last time I used it was in mid-november and after that I have just been trying to check online what can be done? Can you help me with this please? :'-(
完成的
添加一条评论
For anyone still having trouble with this, you can read herefor more information and a video tutorial.
这个答案有帮助吗?
得分 0
添加一条评论
I happened to me too, so I decided to go for the warranty. I started to pack it again, I recall I put a microSD on it so I removed it... and voila!! the tablet turn on! try that and please tell me if works for you
这个答案有帮助吗?
得分 0
添加一条评论
you need to hold on the turn off button for some time.that worked by me and it happened a lot
这个答案有帮助吗?
得分 0
添加一条评论
watch this tutorial by clicking given link you will get somthing...
https://youtu.be/sNcCabxmqiY
这个答案有帮助吗?
得分 0
添加一条评论
Have you tried holding the power button for 10-15 seconds? Most Android devices won't turn on with a short tap of the power button, in my experience.
Pujan shrestha
M-Zone,A complete solution for mobile hardwaring & softwaring
@mobilezonenepal
这个答案有帮助吗?
得分 0
添加一条评论
If you do the holding the power and volume button for 15 seconds and it doesn’t work, try to leave it somewhere that is not hot or too warm for an hour. This helps your tablet or any Samsung device cool down. You might ask why and the answer is simple. You have basically left your device in an over heated place or you have used it nonstop and it has started to heat up, making your device over heated. This happens to me all the time and it’s completely normal. So I hope this helped you guys and I hope this fix’s your problems with your device no turning on or turning on and off.
这个答案有帮助吗?
得分 0
添加一条评论
I have a similar problem if I let one of my tablets sit for a long time. I simply do the volume button and power button trick while connected to power and it starts right up.
这个答案有帮助吗?
得分 0
添加一条评论
Hi - I've tried these solutions (and variations) and none of them worked for me. But then in desperation, I tried this and it worked!!!
Hold down Power and Volume DOWN buttons until the thing reboots. Relief!
这个答案有帮助吗?
得分 0
添加一条评论
I have the same problem, I was playing pubg mobile and the tab was on 5% and quickly charged it but it just turned off and it won't show the charging logo and won't turn on and the back was heating up any help guys?
I really need it to work now bcoz it's my lil bro’s tab and my mom is going to kill me lol.
这个答案有帮助吗?
得分 0
添加一条评论
why won't my new Samsung E.
这个答案有帮助吗?
得分 0
1条评论:
Why won't it what?
完成的
添加一条评论
I gave it a try several times but all I get is the first android screen which states it has 65% charge then it goes off then it goes back to the same screen as before round and round over and over and never stopes unless I press the power button when the screen is blank I think I have pressed every combination of buttons and held every combination for a short time 10 seconds and a long time 2 minutes but it does not start, I also tried every combination both plugged in and not plugged in it is a pain in the arse it's not as if it gets to much work I only use it for maps in my car I just ordered a samsung galaxy tab 7 which I will have to put up with as I have a couple of others but I doubt they would be any good as I have a Asus transformer v1 along with the separate keyboard which also has a extra battery in it which was a great way of doubling up the battery power and I have one one of the samsung galaxy note Pro which I think would be a little large sat in the car as it has a 12 inch screen.
这个答案有帮助吗?
得分 0
添加一条评论
It's Not Working!!! Dang it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
talia stanley 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 53
总计 250,039
