跳转到主内容
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312 个问题 查看全部
Put a iPod classic/video 120gb/160gb hdd in my a1237 MacBook air
I have a original macbook air that the hard drive is starting to go and I would like to upgrade to a bigger size. Is it possible to get a hard drive out of a ipod classic or video to work on the macbook air original A1237?
Does anything special need to be done to get it to work?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
The iPod drive on the Video/Classic (5th and 6th gen respectively) are not SATA drives. they are actually 1.8" Pata (ATA-7) drives. If you do want to try to accomplish this, purchase a Zif-to-USB connector, something like this will work. This will only allow you to format your drive or access it as an external drive. I believe that for A1237 the original Air version the connector is a ZIF (Zero Insertion Force) connector and the connection is PATA. I remember to have read that there are issues with the iPod HDD interface and firmware and that is what makes them unusable for anything else but the iPod.
这个答案有帮助吗?
得分 1
1条评论:
Your correct the early version of the Air is PATA drive.
完成的
添加一条评论
最有帮助的答案
If your iPod is still working I would leave it alone and get a new HD.
If on the other hand, the battery is gone and you know the drive is in good shape you could give it a try.
First, I would get a 2.5 PATA to USB adapter to see if you can format and prep the iPod drive, before opening up your system.
Then you'll need to check your system to see if the drive interface & HD connectors are the same. The Air's have two different HD connector setups (and interfaces PATA & SATA) and your iPod drive might not be the same.
Also don't forget to also measure the drive heights as some iPod drives may not fit the height limit in the air.
Good Luck
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Josh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,305
