跳转到主内容
The sixth generation Grand Prix, a front-engine, front-wheel drive vehicle manufactured by Pontiac, a division of GM. Sold in both coupe and sedan configurations.
40 个问题 查看全部
How do I replace the serpentine belt
how do i replace the serpentine belt on a 2004 pontiac gran prix
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
What engine size are we talking about?
完成的
3.8 l
does motor mount need removed
完成的
@ravendok use the link in my original answer (the light blue "here is"). It is for the 3.8L
完成的
You tube mechanic it worjs
完成的
添加一条评论
1个答案
已选择的解决方案
Alan Calder, here is a good guide. The service manual says "DRIVE BELT REPLACEMENT
Removal Procedure
1. Raise and support the vehicle. Refer to LIFTING AND JACKING THE VEHICLE in General
Information.
2. Remove the front fender liner. Refer to FRONT FENDER LINER REPLACEMENT .
3. Rotate the drive belt tensioner counterclockwise to release the spring tension.
4. Remove the drive belt.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alan Calder 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 36
总计 5,625
