跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
914 个问题 查看全部
How do you fix display that is partially covered in white?
After an insignificant drop, my iPod's display screen is now 75% covered in white. There are also thin colored lines running lengthwise down the display.
When I twist the iPod the white moves, but still covers most of the display.
I believe that the iPod is still functioning, as I am able to (in the area that the white is not covering) choose apps and they do appear (only partially of course where the white is not covering).
I purchased the iPod last Christmas and would hate to replace it with a new one if not necessary.
Any suggestions? Is there, perhaps, a part that I can install to correct this issue?
Any advice is greatly appreciated!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
You can check the female cable receptacle for any bent / broke pins and reseat the cables. Or, plug in the old screen, if it works, you know the new screen is bad.
I pretty much can say after seeing this with several screens that I received in the past, it is probably DOA. It happens.
这个答案有帮助吗?
得分 2
1条评论:
Thank you for your advice/help. Sounds like it may make more sense to just replace the entire unit.
完成的
添加一条评论
You can replace the display assembly, but it is a very hard repair.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for your advice/help. Sounds like it may make more sense to just replace the ipod w/a new one.
完成的
添加一条评论
Take your time doing this repair I always run the battery out before I attempt this good luck
iPod Touch 4th Generation Front Panel Replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
katrina 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 739
