Intermittent display screen related to angle?
I replaced HD and RAM on my 2006? Macbook 2 GHz Intel Core 2 Duo Memory:4GB 667 MHz DDR2 SDRAM
It has been working fine for 2 months.
Now, the screen will black out-- sleep? but won't display anymore. If I almost close it and slowly open the screen it comes on until it's almost 90 degrees...further opening causes black screen.
Intermittent means loose connection? or something worse?
What do I do to diagnose this problem-decide if I can afford or should attempt to fix it.
Thanks
这是一个好问题吗?
Yes thank you. I see "DIFFICULT". I read what a splunger was...I think I'm WAY out of my skill set here. Any advice on this part?
由 georgiaruocco 完成的
The guide is good even for a beginner. But it's not an easy fix. Maybe we can get you to a good tech. Where do you live?
由 mayer 完成的
