'06 Honda Civic stereo code?
I removed the battery in my 06 Honda civic, after I put the battery back my radio/stereo wouldn't work and it kept on asking for a code to put. can anyone help me out on what code I should put?
Josiah, give this a try:"
Call your Honda dealer and give them those numbers. Or just follow the directions on here. Hope this helps, good luck.
这个答案有帮助吗?
I got my Civic’s radio code from this site: https://radiocodevault.com/honda/ its great, got my code in like.. an hour I think? It was sent straight to my email.
MUSIC FINALLY AGAIN! :DDD
这个答案有帮助吗?
Many times there is a sticker on the left side of the glove compartment containing the radio code. Check there first, because sometimes the Honda dealer can charge you to look up the correct code.
这个答案有帮助吗?
Your radio code is unique to your radio, you will need your radios serial number in order to successfully generate a radio code. visit the below website which will explain how you can find out the serial number of your radio and also how you can generate a radio code for your honda civic.
Check it out here... http://freeradiounlocking.com/brands/hon...
这个答案有帮助吗?
过去 24 小时: 8
过去 7 天: 34
过去 30 天: 180
总计 49,123
4条评论
Hi Josiah, I recommend you take a look at the guide on the below website:
http://www.freeradiocodes.com/brands/hon...
It will show you exactly how you can get a radio code for your Honda Civic for free.
由 josephmanu 完成的
Yeah I had this samee issue actually a while back. You can get a radio code here: https://radiocodevault.com/honda
Hope it helps mate! :)
由 James 完成的
hi
I need code for my Honda Civic 2007
I am in Saudia and i am unable to find the code :(
any body who can help me?
由 abdul_elaah 完成的
hi
I am in Dubai and i am unable to find the code :( any body who can help me?
Tried several times the same solution on the https://radiocodevault.com/honda/ but it says VIN Invalid.
由 salahuddinbutt.420 完成的
