跳转到主内容
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
314 个问题 查看全部
Why does the top screen of my DS Bleed(Run)?
Whenever I move the top screen while playing, the image on the top screen runs, But i can manage to play if the screen is set at its normal open position. any movement on the unit causes the colors to begin running. I would like to know the cause of this; and if possible if the problem is fixable. I'd like to make my DS in as good condition as possible so I can give it to a family member.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Sounds like a bad cable. any chance you can post an image of the "running colors"?
完成的
Righto, so I went and took some pictures of it. Apologies for the darkness but it was the only way to make the screen not look blue.
DS 1
DS 2
DS 3
DS 4
Hope this helps!
Edit: The screen is bent only slightly, if at all.
完成的
添加一条评论
1个答案
已选择的解决方案
Use this guide Nintendo DS Lite Upper LCD Replacement and check to make sure the ribbon cable is properly seated. It does look like a bad LCD, but is definitely interesting. If the cable is properly seated and you have no damage to the connector, I'd replace the LCD.
这个答案有帮助吗?
得分 0
1条评论:
Thanks! I'll give it a go, Hoping I just have to reseat the cables and not get a new LCD.
完成的
添加一条评论
添加你的答案
Sedorael 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 529
