跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
3001 个问题 查看全部
flashlight does not work anymore after re-assembly
Hi,
I replaced the display and digitizer of my wife´s iphone 4s according to the steps mentioned in the guide. Everything works after re-assembly except the flashlight. Looks like something is not properly connected ....after checking the ribbon cable of the flashlight multiple times I dont have an idea what I did wrong.
Any idea what went wrong?
Thanks
Andre
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
1个答案
Check that the connector is seeded correctly if it is make sure you have flag turned on lol. If none of them work it must of got damaged
这个答案有帮助吗?
按维修分数 0
评论:
Does the flashlight gets its power via the camera connector? I noticed two electric contact springs on both sides of the connector ... what are they good for?
添加一条评论
添加你的答案
Zipfll 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 479
