跳转到主内容
第四代 iPhone CDMA 版的维修指南。型号 A1349,有8,16,以及32 GB 存储空间的选项。
Can I add a sim card slot to the iPhone 4 CDMA?
Hi, my friend gave me his old iphone 4, but it's on verizon, and I am on T-Mobile, so I was wondering if I can access the iphone's internals and create a sim card slot. I don't really care about looks, I can hide it in a case, I just want to upgrade from my crappy LG. Any help is appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
You are trying to compare Apples and Oranges. One is a CDMA phone (Verizon) while the other one (AT&T, T-Mobile) is a GSM phone. They do have different hardware. So it is not as easy as cutting a slot in the case, the SIM card reader will have to be connected to something that is not supported by the CDMA version.
完成的
Contact T-Mobile they can assist you with a CDMA account now.
完成的
添加一条评论
5个答案
已选择的解决方案
I don't think your idea would be possible - IIRC the case has significant differences compared to the GSM model so trying to shoe horn a GSM board etc into the case will likely not work.
这个答案有帮助吗?
得分 1
3条评论:
But couldn't I just add it onto the back with tape and cover it up with say a case?
完成的
No. You are talking completely different phones in somewhat similar cases.
完成的
is iphone 4 cdma has sim card built in on the back? can i change that built in sim?
完成的
添加一条评论
No you couldn't
这个答案有帮助吗?
得分 0
添加一条评论
alot of difference between the iphone 4s cdma and iphone 4s gsm inside the board and cdma iphone 4s do not work in other country with out of usa and many other country of europ''
这个答案有帮助吗?
得分 0
添加一条评论
I have iphone 4 cdma phone is problem in sim tray
这个答案有帮助吗?
得分 0
添加一条评论
I have the same issue, I am on Mint and my iPhone 4 is stuck on Verizon for all eternity. After trying so hard, I deduced I should just buy a GSM iPhone 4 for about $60 on Amazon with a SIM slot
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Peter Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 16,477
