跳转到主内容
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
550 个问题 查看全部
Dead cylinder no spark.
Changed coils around and still no spark on one of the cylinders. think its the main brain but having trouble locating it. Need help finding it and how to fix it. Kohler Sv740-0020 engine model number 917.288740 Thanks,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Neal, when you say you replaced the coil, I assume you replaced the ignition module on your flywheel stator assembly. If a new module for that cylinder still did not work, I would next replace the rectifier/regulator. Download the service manual for your Kohler engine from here. It has the trouble shooting sequence for the three different ignition systems that are being used. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Neal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 176
