跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2519 个问题 查看全部
iPhone 5 Water Damage/Service Unavailable Error
I dropped my Iphone 5 in water and now says service unavailable.Is there anyway to fix it, everything works except says service unavailable.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
What have you done this far?
完成的
添加一条评论
1个答案
最有帮助的答案
The first thing you need to do is either bust out the tool kit or take it to a repair shop that can tear it all apart and clean the board. I've personally worked on hundreds of water damaged iphones and the motherboard will start forming corrosion almost immediately. This corrosion will get worse to a certain point and can corrode components off the board and make it stop working or develop more issues.
This corrosion will block circuits and damaged components. So its possible the cleaning of the board will resolve all issues. Its also possible it will not, and you may need a replacement antenna or other component to fully resolve.
Hope this helps!
这个答案有帮助吗?
得分 1
1条评论:
What do you use to clean the main board? A friend gave me his iphone to try and make it work after he accidentally fell into a pool.
完成的
添加一条评论
添加你的答案
ABarnes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 293
