跳转到主内容
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 个问题 查看全部
Will the A1496 batery fit in Mid 2011 MacBook Air?
From what I see the new batery (A1496) has the same dimensions but higher capacity and voltage (0,3V). Will it fit in an older MacBook Air? Could you perhaps try if it will work?
Thanks a lot.
Batery in question - A1405 and A1496
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
I got a reply from iFixit:
We did test the newer battery in the older Macbook Air and it seemed to boot up and work just fine for the minute or 2 we tested it
So it seems it works just fine.
完成的
添加一条评论
2个答案
已选择的解决方案
The A1496 battery will work in the following:
1.86 or 2.13 GHz (Late 2010) 13" MacBook Airs
1.7 or 1.8 GHz (Mid 2011) 13" MacBook Airs
1.8 or 2.0 GHz (Mid 2012) 13" MacBook Airs
这个答案有帮助吗?
得分 5
添加一条评论
This is the volunteer DIY help forum... you'd probably get a better answer by contacting iFixit directly.
If this answer was helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Daniel Prokop 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 3,847
