跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
Can't hear caller. Caller can't hear me. Skype Works?!
Intro:
Alright, I'm calling it quits.
I've been fixing iPhones for a little over a year now and have never ran into this problem.
The phone was dropped with the back shattering.
The Problem:
When placing calls, I can't hear anything. The other caller can't hear me. THE LOUDSPEAKER does not work. Using brand new EarBuds does not work.
However, when using Skype, everything works perfectly. When playing music, the loudspeaker works. Headphones work, however, the controls do not work. VOICE MEMO works perfectly.
The Failed Fix Attempts:
1.) Freshly upgraded to 6.1.3
2.) Pressing corners to check for loose connections.
3.) Cardboard Method: Placing a piece of cardboard over connector.
4.) Paper Method: Placing a stack of papers underneath WiFi metal plate.
Any advice is greatly appreciated.
Thanks,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
I have 3 solutions
this works on Iphone 4
i have tested all 3 of them, and have had success with all 3 solutions..
The Problem:
Iphone 4 lower microphone stops working.
recording video and memos works fine, but people cant hear me during calls.
just to clear things up for everyone...
when using video recording, memos or anthing else that can record your voice, the iphone is using the TOP MICROPHONE.
when calling/getting calls the iphone will be using the LOWER MICROPHONE.
When you put it on "Speaker" then the phone will use both.
Solution 1:
Change the Dock Connector
if that wont work... then....
Solution 2:
Click on this link, and follow the instructions, on how to fix the Compiler Chip.
iPhone audio problem: fixing an audio compiler chip fault
sounds and looks wierd...., but yes it works....
done it with multiple phones so far...
if solution 1 does not fix the problem, then solution 2 should help allot.....
should the problem still persist, then you might have a problem with your Home button.
See Solution 3 for more info
Solution 3:
Change the Home button.
this last solution was the problem solver for me... i had 7 dock connecters, new and from other broken phones i tested with.
in the end, the home button just gave up when i was swapping around, then i just replaced it, and Voila.... my microphone was working again, and my home button was working too :D
i cant really explain what really happend, but its my 4th iphone i have had these problems with, and all has been repaired with these 3 simple solutions...
i really hope it can help alot of people in here, with issues with iphone 4 microphones not working
这个答案有帮助吗?
得分 2
添加一条评论
Had a similiar problem with my iphone 4s the phone AUDIO CHIP IS !@#$%^>>>you need to replace it...
NO SOUND FROM HEADPHONE NO SOUND FROM EARPIECE NO SOUND FROM SPEAKER THAT IS THE AUDIO ICU CHIP >>>NEED REPLACEMENT
Or you can try the following fix here:
http://www.youtube.com/watch?v=DPR8qrAcg...
这个答案有帮助吗?
得分 1
添加一条评论
My caller can't hear me ,i can't hear my caller thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
iPhoneProbs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 9,825
