Keyboard & trackpad are dead, screen graphics aren't updating properly
I have the MacBook Pro 15" Core 2 Duo Model A1211, 2.33 GHz Core 2 Duo
At first, it was just that my keyboard wouldn't register typing. Then, my trackpad stopped registering clicks. I could deal with both of those by using external peripherals.
But now, when I use my computer, after a few minutes, the screen starts to glitch out. Specifically, it stops updating the pixels correctly. Like, when I move a window, it'll show the edge that I moved it to, but it'll leave the old outlines of the window there too. It looks sort of like this (except that I'm running OSX, not XP):
Except that it happens for the whole screen, and not just for a subwindow (Also, it's in OSX, and not XP). You can still click on things, and they'll work (I've lucked into making iTunes work once or twice, and it's played audio when I click where I assume the play button is). You just can't see them.
I'm at a loss as to what the issue could be. Is there some root problem that could be causing all three of these issues (the keyboard, trackpad, and window trails)? Or do I have separate issues?
2条评论
under windwos you could try this "You need to follow the steps mentioned below-
a) Right Click on an empty space on the Desktop and select “Properties”.
b) Now select the “Appearance” tab and click on “Effects”.
c) Now uncheck, “Show Windows content while dragging”.
d) Click on “Ok” and then “Apply”." A
Also check the refresh rate and see what it is set as
由 oldturkey03 完成的
As mentioned above, I'm running OSX, not windows. I couldn't get a screenshot of my problem, so I posted a picture of as close an approximation as I could find.
由 Jenee Hughes 完成的
