跳转到主内容
Clothes dryer repair and support guides.
748 个问题 查看全部
dryer wont stay hot or now get hot
I've taken the dryer apart to see whats going on. This is what Ive noticed. The flame does cycle on and off, repeatably, But when it lights a flame, it only stays light for a bout 30 seconds and clicks off for 2 mins then back on for another 30 seconds and so on. I've cleaned the ducts and all inside the dryer. When put back together, it seem to getting hot at first, so i tried a load, then nothing again, i dont' feel any heat again. What part do you think it is?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Thermal Fuse
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
tbelcherztech 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 139
