跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2191 个问题 查看全部
问题已关闭
Screen will not turn on at all!
I had this 4S come in for a screen repair. We replaced the screen, and a week later the customer comes back in saying the screen went out. I checked the phone out, it gets calls but the LCD won't light up. No biggie, tested out a new screen and re did the repair, but the screen still won't light up!
I must have went through at least 5 WORKING screens, but once they are installed they don't work. Even when I pretest the screen on the phone itself(remove back and disconnect the cables), it won't work.
I restored the phone and it worked for about 2 minutes, then I saw RED lines across the top, a few seconds later the LCD started going out.
Now the weirdest part is the LCD's that don't work on this particular phone, work fine on other devices, even the one that started flashing lines and went out.
I'm just stumped, I've repaired hundreds of these phones and have never seen this happen before
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Ok this happened to my friend at boces try first installing the new screen then restarting the phone about 30 minutes later just turn off the phone then wait 30 minutes later then turn it back on if the problem still continues please reply back it doesnt always work for every device
这个答案有帮助吗?
得分 0
1条评论:
Tried this, still didn't help. Phone is recognized through iTunes and I can fully restore it.
完成的
添加一条评论
iPhone 4s. it might one of the connectors on the board that connects to the LCD
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 231
