跳转到主内容
加入维修社区 - 创建账户
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
Screen comes on but does not light up.
I have a PowerBook G4 Aluminum 17" 1-1.67 GHz and it was working fine. All of the sudden the screen comes on but does not light up. I was told that it was probably an inverter board, so I bought a replacement. After a 6 hour tear down and reconstruction it does the same thing. All wires are connected and tight. Any help or ideas would be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It's a widespread myth that the inverter is the problem in these situations (spread mostly by people who have never done a laptop repair), and 99% of the time it's actually the inverter cable, or the screen itself. With MacBooks and PowerBooks it typically ends up being the screen, however you might want to replace the inverter cable first, since it's a relatively cheap part and there is a chance it's the culprit.
Also, before you start spending money on parts, you'll want to connect the laptop to an external display. If that works fine, you'll have ruled out the logic board as part of the problem, whereas if the external display doesn't work, it's possible you've got a video chip issue.
这个答案有帮助吗?
得分 2
1条评论:
Agreed +
由完成的
添加一条评论
添加你的答案
mrclark 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 12
总计 902
