Suwfieya, Without knowing exactly which display you have, I selected the "glossy" from the Mid 2010 MBP 661-5483 Glossy, Display assembly, Here is the compatibility of that:"
MacBook Pro 15.4" 2.0GHz Core i7 (A1286) - Early 2011
MacBook Pro 15.4" 2.2GHz Core i7 (A1286) - Early 2011
MacBook Pro 15.4" 2.2GHz Core i7 (A1286) - Late 2011
MacBook Pro 15.4" 2.3GHz Core i7 (A1286) - Early 2011
MacBook Pro 15.4" 2.3GHz Core i7 (A1286) - Mid 2012
MacBook Pro 15.4" 2.4GHz Core 2 Duo (A1286) - Late 2008
MacBook Pro 15.4" 2.4GHz Core i5 (A1286) - Mid 2010
MacBook Pro 15.4" 2.4GHz Core i7 (A1286) - Late 2011
MacBook Pro 15.4" 2.53GHz Core 2 Duo (A1286) - Late 2008
MacBook Pro 15.4" 2.53GHz Core 2 Duo (A1286) - Mid 2009
MacBook Pro 15.4" 2.53GHz Core i5 (A1286) - Mid 2010
MacBook Pro 15.4" 2.5GHz Core i7 (A1286) - Late 2011
MacBook Pro 15.4" 2.66GHz Core 2 Duo (A1286) - Early 2009
MacBook Pro 15.4" 2.66GHz Core 2 Duo (A1286) - Mid 2009
MacBook Pro 15.4" 2.66GHz Core i7 (A1286) - Mid 2010
MacBook Pro 15.4" 2.6GHz Core i7 (A1286) - Mid 2012
MacBook Pro 15.4" 2.7GHz Core i7 (A1286) - Mid 2012
MacBook Pro 15.4" 2.8GHz Core 2 Duo (A1286) - Late 2008
MacBook Pro 15.4" 2.8GHz Core 2 Duo (A1286) - Mid 2009
MacBook Pro 15.4" 2.8GHz Core i7 (A1286) - Mid 2010
MacBook Pro 15.4" 2.93GHz Core 2 Duo (A1286) - Early 2009
MacBook Pro 15.4" 3.06GHz Core 2 Duo (A1286) - Mid 2009
from here. According to this the 2011 will be a fit.
I added some more part numbers, since there are 2 more displays that are available for this model.
661-5477, Hi-Res Glossy Display assembly:
661-5478, Hi-Res Anti-Glare Display assembly
So , if it is the glossy display it will fit. If you are still unsure, take a look at your panel once you have it removed and compare the model numbers. Also, it will help if you ask the person the has the 2011 display assembly, which assembly that is and may be he/she will provide you with that number.
Hope this helps, good luck.
6条评论
Suwfieya , lets start off with identifying your computer properly. what are the last three digits of your serial number?
由 oldturkey03 完成的
Last 3 digits/numbers are 138. Last letters are AGZ.
由 Suwfieya 完成的
Does this look like the specs for your computer:" 2.66 GHz Core i7 (I7-620M)
Intro Date: April 13, 2010 Disc Date: February 24, 2011
Order No: MC373LL/A Model No: A1286 (EMC 2353*)
Subfamily: Mid-2010 15" Model ID: MacBookPro6,2
Std RAM: 4 GB Std VRAM: 512 MB*
Std Storage: 500 GB (5400 RPM) Std Optical: 8X DL "SuperDrive" ?
If so my answer stays incorrected:-)
由 oldturkey03 完成的
Yes this is it. I've added another 4gig ram to it. So does this mean that the 2011 display assembly will fit with my mac? Thank you for your help.
由 Suwfieya 完成的
If it is the Glossy display, then it does look like it fits. Check the list in my answer. Hope this helps.
由 oldturkey03 完成的
显示更多的1条评论
