跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2519 个问题 查看全部
Help! NO SIM CARD / BAD ESN / Can I unlock?
Hello! I do need help on a SPRINT / iPhone 5 / 16gb / Black. Able to fully replace the front screen and did a restore on the item. But now the iPhone states there is no SIM CARD and to retry. It appears there is no SIM CARD inside. Can I purchase a third party one? I cannot get access to the home screen. I would like to use this as an itouch, perhaps even an international iphone. It does have a bad esn. Is it possible to get it unlocked? Please help me! I do now know what further steps to take. I'm stuck! Thank you!
Update
@ALL - LIKE WOULD THIS WORK?
http://www.ebay.com/itm/NEWEST-GPP-iOS-6...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
unlocked as in for a different carrier? with a bad ESN, most likely not.
完成的
@oldturkey03, well I saw there are services to clear the BAD ESN and make is clean.
完成的
添加一条评论
2个答案
最有帮助的答案
You will need a sim card to finish the activation process. I keep a little baggy of old ones with no service on them for that exact purpose. See if you can find one or take it to the carrier its for store and maybe they can put an inactive one in it just to complete the activation and get it working. then take it back out.
Hope this helps!
这个答案有帮助吗?
得分 1
1条评论:
@gizmo4sal3 Thanks for the help! does it matter if I use a Verizon SIM card? Since this is a SPRINT phone?
Also, how would I proceed with making making this iPhone an actual phone and on a carrier? Possible make it phone where I can use in other countries.
完成的
添加一条评论
You can get 3rd party Sims/microSims that could potentially work. If you want to use it as an Itouch you can probably get any old sim that will fit and put it in. With Sprint though usually it says you're connected to Sprints network even without a SIM, atleast it did with my 4s that was locked to Sprint. But I couldn't for the life of me unlock it from Sprint. Supposedly there was a way awhile back for jailbroken Iphones but it got patched. I'm not 100% sure about Iphone 5. I suggest googling if no one hear can help.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the help and advise. I will try sticking my verizon SIM in there to see if it at least get to the home screen. I contacted this service and they claim they can do it. What do you think? www.cleanyouresn.com
完成的
添加一条评论
添加你的答案
Aus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 11,124
