跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
Water damage. Working but won't restore.
Have a 4S that has water damage but everything seems to work except it won't restore. When connected to iTunes it says the phone is in recovery mode. When I click restore it says "Software for this iPhone is not currently available. Make sure you have the latest version of iTunes and try again."
Have the latest version of iTunes.
So, not sure what the deal is. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You could try and manually download the latest IOS software and then when you click restore....hold shift and click restore. It will then open a box asking you to point to the software you want to restore. Maybe it will allow you to do it this way? You should also try putting the phone into DFU mode and see if it will restore that way.
这个答案有帮助吗?
得分 0
1条评论:
Yeah, I did DFU already. No difference.
Ill try to manually load the software.
Ive just never seen "Software for this iPhone is not currently available. Make sure you have the latest version of iTunes and try again" before.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 325
