PowerBook Al 1GHz - 4 Beeps at Startup
received today a AL Book
seller said that it beeps 3 times, but unfortunately - it beeps 4 times (light flashes 5 times) - so the boot rom should be faulty
is there any way to fix this problem?
The boot rom is not on the hard drive but in a flash memory module on the logic board (just like the integrated memory modules). The boot rom is an instruction set that the computer use before loading the OS. I think the boot rom can only be modified by a firmware update.
这个答案有帮助吗?
thanks for the reply the problem would be, that there is no firmware update listed (or i'm to blind to find it)
was there a ASD for the 1ghz or was the ASD starting at the 1,33 (but then would the ver. # 2.5.7 would not make much sense) - a simple yes or no answer to this particular question would be enough
If the boot room module itself is faulty I think that means a logic board replacement. If the boot rom image is corrupted maybe it can be reflashed but I really don't know (Google search..). Also the boot rom module might be physically replaced by a working one (salvaged from a dead board) again I don't know if it can be done....Sorry
ok thanks,
i will try something with the ASD, also found some firmware images - but first i will read a little bit more about that - in the morning, it's almost 12:38 am - bedtime ;-)
to "close" this question: i sold the powerbook - the buyer has a good logicboard for the beautiful case (no scratches or something else) - well, some things can not easily fixed - the only way would have been an otherwise toasted board, swapping the chips would have been the easiest way to fix it
Here's Apple explanation of the different startup beeps: http://support.apple.com/kb/HT1547
这个答案有帮助吗?
Good info + Ralph
right, but can the 4 beep problem be fixed ?
First thing I would do is zero out the hard drive to eliminate boot block problems
I replaced the hdd - same beeping
there is nothing on the screen, wont boot from the setup disk (optical drive is ok, took one of my spare drives)
What's your status on ASD issues? I have the 3S123 with updates 2005.06.07 & 08. Have anything to trade? Contact at mayer@door.net
Hi' Usually means bad ram slot. (Usually) the bottom one) Try removing the ram in the bottom slot and see what happens. Ralph
这个答案有帮助吗?
that would bee the 3 times beeping - but 4 times is a boot rom error
4 beeps = no good boot images in the boot ROM (and/or bad sys config block)
You are correct sir--see mayer's answer. Ralph
You can read this page from Apple on the issue to see what the problem is.
You have a bad boot ROM. Back in these days, there was no real way to recover the BIOS as there is today. You will probably need a new motherboard that works to fix the problem.
这个答案有帮助吗?
I know that problem, but i find it hard to believe that there is simply no way to fix a "minor" problem like that
The swap should be the easiest job, i have the tools and a'm able to use them - getting a otherwise fried board is the problem.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,827
