跳转到主内容
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 个问题 查看全部
Fan connector won't insert?!
Hi!
I just repaired the fan of my Macbook Air '13.
Now I have another issue. The cable won't insert into the logicboards connector!! After lifting the "flap" i can only get it in halfway. The white line on the cable is where it stops inserting! Please help, my fan doesn't run at all !
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Can you take some pictures of the cable and the location on the logic board so we can see what you'er encountering here. Also please supply the last four digits of your serial number so we can correctly identify the exact model.
完成的
http://gyazo.com/678f2fd98a88f0da34d9b80...
There you have a picture! Sorry if it's not clear, my camera is awful. As you can see it's not fully inserted!
Last 4 digits: DJWT
完成的
添加一条评论
1个答案
已选择的解决方案
Review this iFixIt guide MacBook Air 13" Mid 2011 Logic Board Replacement. Look at Step 7 picture note the white line is parallel to the connector body. In your picture it appears the ribbon is at an angle. Release the latch again and squarely insert it again. Did it get in the rest of the way?
这个答案有帮助吗?
得分 1
5条评论:
It is paralllell now but still won't get in!
完成的
Take a picture of the end of the ribbon cable so we can see whats stopping it. Take a picture of both sides as close up as you can get that still is sharp. You may need a new fan if it's damaged.
完成的
I have no access to computer atm (obviously) but i'll upload later. Can i solder it?
完成的
Any luck on the pictures?
完成的
http://gyazo.com/d18c7e1ab69642d04d0ac0e...
http://gyazo.com/c0c250598e87cbc57736970...
There you go!! But still back to my former question: can I solder it?
完成的
添加一条评论
添加你的答案
Fanssuck 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 206
