跳转到主内容
The HP LaserJet CM1415fnw is a multifunction color printer produced by Hewlett Packard.
19 个问题 查看全部
ADF Won't pick up paper
The ADF(automatic document feeder) will not pick up paper, either a single sheet or multiple sheets. HP and my extended warranty says it can't be fixed, printer is only a bit over one year old. Anyone know if a ADF unit is available?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
Maybe I will dismount the complete unit to replace this (cheap?) cable up to ADF unit. Could be the problem as my ADF does nothing than saying - no document.
Anyone having a tech repair guide for me?
这个答案有帮助吗?
得分 1
添加一条评论
Inkjet printers are cheap enough that if they break, buy a new one and recycle the old one. Other types of printers can and should be fixed.
这个答案有帮助吗?
得分 0
2条评论:
It doesn't seem broken to me; more like a gear cog out of sync due to clearing paper jam. Would appreciate guidance how to realign.
完成的
The paper get crashed after that the printer stop printing as if it did not receive the order to print
完成的
添加一条评论
The paper get crashed and after removing the torn paper the printer stops printing, as if it did not receive the order to print
just now by fmankarious
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Roger 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 15
总计 3,187
